Inventor General
Active Member
sphys
Message 1 of 7 (236 Views)
A few (hopefully simple)
236 Views, 6 Replies
09-24-2012 10:26 AM
Hi there!
I got a few questions:
My problem is getting a tube in between two flanges:
I did use a mate-mate constraint with offset 60 mm to get both flanges 60mm apart with the correct orientation and another mate-mate constraint to align the axis so that they're properly aligned (correct distance, both holes aligned, right faces facing each other). I did cut out the hole by selecting a shape (I drew some new lines and used the existing sides) and revolving it, the smaller flange having a 6mm deep reception for the tube, the larger a 10mm deep.
Now comes the tricky part:
I'd like the tube to connect these two parts.
The tube is 60mm+10mm+6mm long, has an outer diameter of 38mm and an inner diameter of 35mm. So I created a part with these dimensions and used an "Assemble-Insert" to fit it into the hole of the bigger flange. That worked fine, but:
  • Is there a way to do this better? Especially, can I have the length been driven by the distance between both flanges (which is what I'm interested in, the tube only has to fit)?
Also it seems like there is a small gap between the tube and the receptacle the smaller flange (check drawing) and the tube being pushed a little bit too far into the larger flange.
  • I had the idea of using a mate-mate constraint on one end of the tube and the receiving "step" in the flange, but I can't get in there (the flange is blocking the view). How can I do this?
  •  And last question for now: as you can see in the drawing I added a section view of the part. However, I can move the view only up or down, thus either overlapping other views or being moved out of the sheet. How can I move it a little bit to the side?
Any help will be greatly appreciated!
Active Member
sphys
Message 2 of 7 (233 Views)
Re: A few (hopefully simple)
09-24-2012 10:27 AM in reply to: sphys
I don't now if part files (ipt) are automatically included in an iam file, so here are the last two missing ones:
JDMather
Message 3 of 7 (214 Views)
09-24-2012 11:33 AM in reply to: sphys
Right click on the view and select Alignment>Break
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
JDMather
Message 4 of 7 (211 Views)
09-24-2012 11:37 AM in reply to: JDMather
I opened up a couple of your parts and noticed that they were not constrained and duplicate axis and workplanes not needed.
I recommend starting here http://home.pct.edu/~jmather/skillsusa%20university.pdf
Active Member
sphys
Message 5 of 7 (166 Views)
09-25-2012 01:48 AM in reply to: JDMather
Thanks for the PDF! That's a great find, I'm right now working through it.
Active Member
sphys
Message 6 of 7 (155 Views)
09-25-2012 03:38 AM in reply to: sphys
Ok, I still got a question.
When opening the assembly I select "View->Half Section View" to see where the tube doesn't quite reach the reception step.
However, when I go back to "Assemble->Assemble" to place a mate-mate constraint the section view disappears again and I can't see the gap.
How can I make the section view stick?
*Pro
sbixler
Message 7 of 7 (145 Views)
09-25-2012 04:19 AM in reply to: sphys
It's a secret!  You have to be a member of the club to know how to make your assembly sections stick!
Actually, it's simple, just not obvious-- after defining your section, you have to right click and select Done.  There are other things that you can do with the section in that menu, too, but there is no prompt or any other way for you to know that there is another step required.
Hint: it's always helpful to know what version of Inventor you're using.  Put it in your signature so you don't have to remember every time.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
