Inventor General
Active Member
Message 1 of 8 (419 Views)
A couple of update questions regarding extrusions and derived sketch blocks.
419 Views, 7 Replies
10-27-2012 06:44 AM
First off if I update a sketch block in a derived part, how do I get the sketch blocks to update?  Do I have to delete derived item, and rederive it?
Also if I modify a sketch block that is used for a extrusion, how do I get the extrusion to update?  Do I have to delete extrusion and rextrude?
Thanks.
Message 2 of 8 (406 Views)
Re: A couple of update questions regarding extrusions and derived sketch blocks.
10-27-2012 10:16 AM in reply to: bcadenza
Q1. this quesion doesn't make sense.  If  you update a sketch block it IS uptdated.  What do you really mean?
Q2. No
Q3. No
Do you have some files that are giving you trouble?  It will be much easier to guide you to a solution if you attach actual files here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Member
Message 3 of 8 (391 Views)
10-27-2012 06:30 PM in reply to: JDMather
Regarding the first question about the sketch blocks, you are right they are updating.  I must have not saved the part or something.
Regarding the second question about the extrusions updating, let me give you an example.  If I have a sketch extruded, and I move a part, then the extrusion will match that.  But lets say I try to put a hole in the middle of it using a circle, and then finish the sketch, the extrusion does not show a hole, so I have to delete the extrusion and re-extrude.  Similarly if I add a sketch block item to sketch after it is already extruded, then I do not see it reflected in the extrusion.  Does this sound wrong?
Message 4 of 8 (386 Views)
10-27-2012 06:46 PM in reply to: bcadenza
bcadenza wrote:
Regarding the second question about the extrusions updating, let me give you an example.  .....
The rest is meaningless to me without a file.  A true example would include an attachment of an ipt file.
Active Member
Message 5 of 8 (370 Views)
10-28-2012 07:52 AM in reply to: JDMather
Thanks for your help.  Attached is a part I made.  I first made the sketch then extruded it, then added a new circle that want to be a cutout of the extrusion.
Message 6 of 8 (366 Views)
10-28-2012 09:05 AM in reply to: bcadenza
It is not clear to me what you are trying to do.
There are no Sketch Blocks in the file?
To edit a sketch simply double click on the sketch and then double click on dimension to change, then exit sketch and the part should update.
Active Member
Message 7 of 8 (362 Views)
10-28-2012 09:35 AM in reply to: JDMather
Yes if I change a dimension the extrusion does get update.  My question is regarding the adding of a featthat like a circle that I want to be excluded from the extrusion. In my part I attached, if you look at the sketch there is asecond circle that is not excluded from the extrusion as it is was added after the extrude command.  I guess I either have to do a second inverted extrusion or delete extrusion and repeat extrude.
Message 8 of 8 (356 Views)
10-28-2012 10:37 AM in reply to: bcadenza
bcadenza wrote:
... if you look at the sketch there is asecond circle that is not excluded from the extrusion as it is was added after the extrude command.  I guess I either have to do a second inverted extrusion or delete extrusion and repeat extrude.
You should not need to delete anything.
Double click on the extrusion.
Make the selection tool for Profile active.
Ctrl select the existing profile to unselect and then click again to select the edited profile.
(you might have to click in multiple areas of the profile if you want to remove islands from the extrusion.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
