What is the best way to bring an autocad 3d model into inventor as a part or assembly. Right now I am creating a stp file then bring it into inventor and save as ipt.
Tom
Solved by jtylerbc. Go to Solution.
File Open(Option Import) of native DWG seems pretty easy to me.
>How do i save as ipt
Click Save.
>use the model in an assembly?
Place Component.
Are these trick questions?
@Anonymous wrote:I open the dwg and have a 3d model. How do i save as ipt or use the model in an assembly?
Tom
If you're having to ask those questions, I suspect you missed part of JD's instructions. You can't just open the file, you have to click the Options button on the Open dialog box, and pick "Import."
Once you've gotten past that point, the results don't look any different than you'd get from a STEP file, so you should know what to do from there.
