Inventor General
Member
gstaver45331
Message 1 of 9 (268 Views)
3d Grips missing
268 Views, 8 Replies
01-02-2013 11:17 AM
I have a customer who has a Microsoft Windows Small Business Server 2011 setup. The are using Inventor 2012. All of the projects are stored on a share on this server. All of the workstations are Windows 7 x64 and are joined to the domain. Everything works fine except they cannot access the 3D Grips while logged in as a domain user. If the log into their workstation as a local user rather than a domain user then the 3d Grips are available. How do I make it so that the 3D Grips are available while logged in as a domain user?
Member
gstaver45331
Message 2 of 9 (266 Views)
Re: 3d Grips missing
01-02-2013 11:19 AM in reply to: gstaver45331
I should add that each domain user has local admin rights to their own pc.
*Pro
sbixler
Message 3 of 9 (227 Views)
01-03-2013 04:23 AM in reply to: gstaver45331
It might be as simple as Options settings, which are specific to the user login.  Check Application Options > Part tab > Enable 3D grips.
On the other hand, why do they need 3D grips?  I have never used them except to play with when the functionality was first introduced.  I'm sure they're useful in certain kinds of design work, but they also can tempt a user to take shortcuts that create problems down the road.  But I'm willing to learn if someone can demonstrate their usefulness.
JDMather
Message 4 of 9 (220 Views)
01-03-2013 05:03 AM in reply to: sbixler
sbixler wrote:
On the other hand, why do they need 3D grips?  I have never used them ......
That was my first reaction, "What are these 3D Grips you speak of?"
OK, I would be concerned if there was some functionality that wasn't available in the scenario described - even if I never use it.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
gstaver45331
Message 5 of 9 (194 Views)
01-09-2013 06:53 PM in reply to: gstaver45331
The issue has been resolved. It was a security issue with some Inventor registry entries. Once I changed those then it started working. Thanks to everyone trying to help me.
New Member
JLiraBakerRisk
Message 6 of 9 (50 Views)
06-04-2014 10:53 AM in reply to: gstaver45331
I am creating a 3D solid model. And it was fine until today. I lost my 3D Grip arrow to allow me to adjust the extruded height. I create a box or circle and then i extrude it to the desired height. But, then if i want to adjust the height of that, i can't because the arrow grip, that allows you to be able to click on it and drag it to a new height or type in the distance i want to move the height to is missing. I didn't change any system variables, not on purpose anyway. Can anyone help?
JDMather
Message 7 of 9 (35 Views)
06-04-2014 02:36 PM in reply to: JLiraBakerRisk
Simply edit the feature.
Are you using Autodesk Inventor
or
are you using Inventor Fusion?
New Member
JLiraBakerRisk
Message 8 of 9 (32 Views)
06-04-2014 02:40 PM in reply to: JDMather
I am actually using AutoCAD English 2014. If I close the drawing and reopen it, i lose that feature or the grips/arrow that allows me to stretch the model. But, if i leave AutoCAD and the DWG open and just continue, it maintains the editing feature. Crazy. I never had that problem.
JDMather
Message 9 of 9 (27 Views)
06-04-2014 03:16 PM in reply to: JLiraBakerRisk
You have posted your question in the Inventor forum.
I recommend you post your question over here
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/bd-p/706
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
