Inventor General
Active Member
mecad
Message 1 of 4 (272 Views)
3Gb switch
272 Views, 3 Replies
09-12-2011 10:57 PM
I have to run a 32 bit system at the moment, have seen several posts re 3Gb switch and was thinking turning it on.
Question is , are there any downsides to doing that either inside or outside inventor?
Mike
Product Support
Daniela_Koloszko
Message 2 of 4 (246 Views)
Re: 3Gb switch
09-13-2011 04:54 AM in reply to: mecad
If you use Inventor 2012, it is not recommended because of the following reasons:
http://beinginventive.typepad.com/being-inventive/2011/06/use-of-3gb-switch-with-inventor-2012-on-32...
If you use an older version of Inventor, please see this document for more details:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9583842&linkID=9240697
Daniela Koloszko
jtylerbc
Message 3 of 4 (237 Views)
Re: 3Gb switch
09-13-2011 05:53 AM in reply to: mecad
We used to run it on some computers at my previous company, mostly as a stalling tactic until we could get some XP 64 bit machines.
We did notice some odd behaviors from time to time in other programs.  It was nothing really predictable, but some of the intermittant issues we saw were:
Our legacy Ideas CAD system hated it, and sometimes wouldn't even start up in 3GB mode.
On some computers, screen savers would not activate while in 3 GB mode.
Increased random crashes of other programs (non-Inventor) while running them at the same time as Inventor.
No issues were ever seen with Inventor - it was always side effects somewhere else in the system.
These are the ones I remember (it's been a couple of years since I was there).  The conclusion we came to was to only use the 3GB mode when we actually needed it, and run normally the rest of the time.
John Tyler
Inventor 2013
Windows 7 64 Bit
Active Member
mecad
Message 4 of 4 (202 Views)
Re: 3Gb switch
09-13-2011 08:36 PM in reply to: jtylerbc
Thanks for replies, will probably leave it off as I am running Inv 2012, Answer is to upgrade to 64bit as soon as can be justified. .
Mike
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
