Hi
is it possible to create 3D sketch from text?
I need it for engraving as a toolpath and for drawings.
Emboss tool is more suitable for styling and visualisation.
Attached sample from Pro-E:
Hi
nobody knows if Autodesk products can create a STEP file with a text transformed to wires?
Autodesk Product Design Suite Ultimate 2013 SP1.1
In the model you can create a sketch and text is an option in the Draw panel. Make a text object, select the font and size you need and then use Extrude to "cut" the text into the object. Then use the Export command to export a STP file.
If I understand correctly this is what you want.
See attached
Yes, Extrude or Emboss is the simplest way. But plastic parts needs add a draft and it is a real pain in the.... For CNC machines is enough to use wires as a toolpath and the tool makes shape inclusive draft and fillets.
Does anybody from Autodesk know how to fix it?
