Inventor General
Active Member
Message 1 of 4 (225 Views)
3D sketch from text
225 Views, 3 Replies
09-12-2012 03:40 AM
Hi
is it possible to create 3D sketch from text?
I need it for engraving as a toolpath and for drawings.
Emboss tool is more suitable for styling and visualisation.
Attached sample from Pro-E:
Active Member
Message 2 of 4 (176 Views)
Re: 3D sketch from text
11-16-2012 02:54 AM in reply to: klapec
Hi
nobody knows if Autodesk products can create a STEP file with a text transformed to wires?
Autodesk Product Design Suite Ultimate 2013 SP1.1
Distinguished Contributor
Message 3 of 4 (148 Views)
11-16-2012 12:41 PM in reply to: klapec
In the model you can create a sketch and text is an option in the Draw panel.  Make a text object, select the font and size you need and then use Extrude to "cut" the text into the object.  Then use the Export command to export a STP file.
If I understand correctly this is what you want.
See attached
Stuart Kinzel
Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
8GB memory
Windows 7 64bit
Active Member
Message 4 of 4 (113 Views)
11-18-2012 10:34 PM in reply to: SKinzel
Yes, Extrude or Emboss is the simplest way. But plastic parts needs add a draft and it is a real pain in the.... For CNC machines is enough to use wires as a toolpath and the tool makes shape inclusive draft and fillets.
Does anybody from Autodesk know how to fix it?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
