Inventor Forum
3D Sweep in Standard Part
20 REPLIES 20
Message 1 of 21
385 Views, 20 Replies
I really under the gun on this one.
In MDT I could use the 3D part path and create a lanyard in a short amount
of time.
Can I accomplish this with Inventor?
I have tried to "stepout" the file from MDT, but Inventor will not import
it.
I have posted an example to CF under "Lanyard"
Thanks.
-Ken
20 REPLIES 20
Message 2 of 21
Sweep
draw a circle -- one sketch
draw a line that the cable will follow-- second sketch
sweep.
Ole Germer
Helping create better involute profiles for gears
http://www.geocities.com/olegermer/index.html
"Ken Schumacher" wrote in message
news:ECE0D8C66786DE66F7CD77947428603C@in.WebX.maYIadrTaRb...
> of time.
> it.
> Thanks.
> -Ken
Message 3 of 21
if the loop is in one work plane or sketch and second loop is in another
plane, there will be no need for 3d sketch.
in fact make it out of 3 parts and make it an assembly
Ole
"Ole Germer" wrote in message
news:E05BD11C8DA0FFD6080AB35158E0807E@in.WebX.maYIadrTaRb...
> Sweep
> sweep.
> Ole Germer
amount
> > of time.
import
> > it.
> > Thanks.
> > -Ken
Message 4 of 21
Sound easy if you've done it before.
How about an example?
> Sweep
> sweep.
> Ole Germer
amount
> > of time.
import
> > it.
> > Thanks.
> > -Ken
Message 5 of 21
I will post something Give me a few minutes.
Ole
news:B4F0AA4F18A1D060D57772E3710511B9@in.WebX.maYIadrTaRb...
> > Sweep
> > sweep.
> > Ole Germer
> amount
> > > of time.
> import
> > > it.
> > > Thanks.
> > > -Ken
Message 6 of 21
You'll have to look at the jpg in CF.
news:AE0C73A5127E66DE0F511CFB8EBA2E76@in.WebX.maYIadrTaRb...
> Ole
> > Sweep
> > sweep.
> > Ole Germer
> amount
> > > of time.
> import
> > > it.
> > > Thanks.
> > > -Ken
Message 7 of 21
Thank You. 🙂
news:5671A7C82E63839F2F58EE19FC085964@in.WebX.maYIadrTaRb...
> Ole
> > > Sweep
> > > sweep.
> > > Ole Germer
> > amount
> > > > of time.
> > import
> > > > it.
> > > > Thanks.
> > > > -Ken
Message 8 of 21
Also,
If you are really under the gun on it, in mdt use
AMAcisout command, then open>.sat in inventor. It'll take it
right in and make a base solid part.
darvin
Message 9 of 21
Thanks Darvin!
I can live with that to get me out of pistol range. 🙂
Would still like to know if this is possible in IV though for future
reference.
Thanks again!
"darvinv" wrote in message
news:29469494E368C01B42BE97B936022CC1@in.WebX.maYIadrTaRb...
> Also,
> darvin
Message 10 of 21
I did post something. Real easy!!
Ole Germer
Mechanical Machine Design and Drafting Service
http://www3.sympatico.ca/ole.germer/index.html
news:6704DF7106BBA645E54367B4EE4F8630@in.WebX.maYIadrTaRb...
> Thanks Darvin!
> reference.
> Thanks again!
> > Also,
> > darvin
Message 11 of 21
Thanks Ole!
I will study your example for future use.
What if you needed to have an angled work plane in there?
news:6E172101A30FDF02B1D7F1094C1E5C76@in.WebX.maYIadrTaRb...
> Ole Germer
> > Thanks Darvin!
> > reference.
> > Thanks again!
> > > Also,
> > > darvin
Message 12 of 21
Glad that helped,
As Ole said, create in place, as subassembly, is
probably the best way for inventor. The yoke on a tap, then
the path and sweep through whatever hole it attaches to,
using in-line work features, then add a swage. It'll look
sharp and respond to changes in the assy.
darvin
Message 13 of 21
That's *WAY* over my head.
I need to get some serious training here.
news:5934AD7BDC5C766F543FB5B2399DADFA@in.WebX.maYIadrTaRb...
> Glad that helped,
> darvin
Message 14 of 21
Construct an angled workplane. See Inventors help. Explained better by
AutoDesk.
Ole
news:986815D1BDBF893EED9AFC4E8B5A80C6@in.WebX.maYIadrTaRb...
> Thanks Ole!
> > Ole Germer
> > > Thanks Darvin!
> > > reference.
> > > Thanks again!
> > > > Also,
> > > > darvin
Message 15 of 21
Not to be a crass, but I haven't found anything to be explained better by
AutoDesk.
I think they could have done a much better job with the help section and the
hard copy book.
news:9CF5556EA05F9AB30CF1FEEF33B3F828@in.WebX.maYIadrTaRb...
> AutoDesk.
> Ole
Message 16 of 21
Ken,
Check out these http://www.inventorparts.com/Animations/Default.htm,
created by Charles Bliss, for an excellent tutorial on creating 3D Sweeps.
Mike
Message 17 of 21
Thanks Mike,
Will do.
"Mike Maenpaa" wrote in message
news:D77B83EAF6F0C5BB369F7041574D8BCC@in.WebX.maYIadrTaRb...
> Ken,
> Mike
Message 18 of 21
Yeah ... It's pretty easy now with R6. I put a quick example in CF.
~Larry
> of time.
> it.
> Thanks.
> -Ken
Message 19 of 21
Th3 3D Intersection feature may be useful in your situation if it needs to
wrap around parts.
~Larry
> Glad that helped,
> darvin
Message 20 of 21
kewl,
That's something I haven't even gotten close to
exploring yet. I do a lot of webbing components and this
might be just the thing to get me over the top in accurate
modeling of those kind of problems.
so much to learn, so little time,
thanks,
darvin
