Inventor General
Member
Megakuk
Message 1 of 4 (182 Views)
3D Sketch
182 Views, 3 Replies
06-06-2012 07:08 AM
Can you guys please fire the guy who programmed the 3D sketch tool? Its probably the worst tool I ever used and you can't really create a good constrained sketch with it. Nobody at this company or anyone I know, wants to use this due to its over complicated layout/lack of intelligence. I want to kill myself every time I need to use it.
Best Regards
Benny Kristiansson
*Expert Elite*
JDMather
Message 2 of 4 (166 Views)
Re: 3D Sketch
06-06-2012 09:10 AM in reply to: Megakuk
3D sketches work fine.
Nearly every 3D sketch I create is actually constrolled with 2D sketches.
Very easy to create.
Very easy to control.
Very easy to edit.
Rock solid.
Attach your file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
Megakuk
Message 3 of 4 (137 Views)
Re: 3D Sketch
06-06-2012 11:28 PM in reply to: JDMather
Well I've used this to create 3D sketches with Frame Generator but in this case I'm trying to create an pipe with complicated geometry. And that is not an easy task when you have to create an 2D sketch for every change of direction. 3D sketch should be able to be edited in a similar way as 2D sketches but it isn't even close. Maybe you can give me an link how to create an complicated pipe?
*Expert Elite*
JDMather
Message 4 of 4 (126 Views)
Re: 3D Sketch
06-07-2012 04:36 AM in reply to: Megakuk
Works very easily here.  Post your example done your hard way.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
