Inventor Forum
3D Mouse Suggestion
7 REPLIES 7
Message 1 of 8
1142 Views, 7 Replies
3D Mouse Suggestion
What brand of 3D mouse would be recommended for use with Inventor 2013?
Jason
7 REPLIES 7
Message 2 of 8
pball
I have the 3Dconneciox Space Navigator and I quite like it. It's really the only 3D mouse I've heard of so this is a one sided suggestion.
http://www.3dconnexion.com/products/spacenavigator.html
It lets you pan/zoom/rotate all at the same time and it only took a few days to really get used to it. The basic one has two buttons which can be programmed to do various things, like zoom all.
Message 3 of 8
JDMather
in reply to: pball
Ditto on Navigator - I have more advanced model too, but only use the two buttons anyhow.
I prefer to change the default zoom/pan behavior.
Message 4 of 8
BarryZA
in reply to: JDMather
And within a week it becomes a "how did I ever live without this" scenario.
Message 5 of 8
blair
in reply to: BarryZA
Ditto, the first day take motion sickness pills and get familar with the "Home" view icon. After that you won't be able to work with Inventor without a 3D Motion Controler and will wonder how you ever worked without one.
Delta Tau Chi ΔΤΧ
Message 6 of 8
stevec781
I use the spaceball 5000 (usb) with an old driver.  Works fine, I find the ball more comfortable than the new ones, and they are cheap on ebay.
Message 7 of 8
JDMather
in reply to: stevec781
What OS are you using?
I have 25 of these things that I haven't been able to get to work since changing to 64-bit Win 7.  (don't think I tried older driver)
Message 8 of 8
stevec781
They work fine on win7 64 and winXP 64 with Inv 2010 - 2013 using driver from 3dconnexion web site.  Its a bit slow with fusion but not sure if that's just a fusion problem.  Some other posts complain about fusion being slow to rotate with newer devices as well.
