Inventor General
WILLIAMF
Message 1 of 7 (272 Views)
3-D sketch export
272 Views, 6 Replies
01-28-2013 06:11 AM
Can a 3-D sketch be exported from a part file an imported or pasted into an assembly file? I see an option in the browser for 2d sketch copy but not for 3D sketch.
Dell Precision T3500
Windows 7 Pro
Quad Core Intel Xeon
6 Gb SDRam
NVIDIA Quadro
Product Design Suite 2014 Premium
JDMather
Message 2 of 7 (271 Views)
Re: 3-D sketch export
01-28-2013 06:14 AM in reply to: WILLIAMF
Why would you ever need a 3D sketch at the assembly level?
Simply place part file with the 3D sketch into the assembly file.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
WILLIAMF
Message 3 of 7 (262 Views)
01-28-2013 06:31 AM in reply to: JDMather
I need to save an assembly file as iges so the 3D sketch in the part is editable for an vendor to place work points at the intersecting curves.
When I save a copy as IGES I dont see the 3D sketch in the part even though the part  file was saved to include 3d sketch.
Therfore I figured I could just copy and paste the 3D sketch into the IGES.
Windows 7 Pro
6 Gb SDRam
NVIDIA Quadro
JDMather
Message 4 of 7 (244 Views)
01-28-2013 07:57 AM in reply to: WILLIAMF
I just tried an experiment and it worked fine for me.
What Options do you have set (show screen capture) on open of the IGES file?
WILLIAMF
Message 5 of 7 (242 Views)
01-28-2013 08:05 AM in reply to: JDMather
A simple part (IPT) to IGES is no problem.
The issue is I have an assemblt (IAM) 2 parts. One part has the 3D sketch. When I sav a copy as IGES, then open the IGES I cant edit the 3D sketch.
Hope that is clear. The help section says it can be done.
Windows 7 Pro
6 Gb SDRam
NVIDIA Quadro
WILLIAMF
Message 6 of 7 (236 Views)
01-28-2013 08:15 AM in reply to: WILLIAMF
Here is the import dialouge window for iges
Windows 7 Pro
6 Gb SDRam
NVIDIA Quadro
WILLIAMF
Message 7 of 7 (223 Views)
01-28-2013 08:42 AM in reply to: WILLIAMF
Thats odd.
If I start a new IPT and derive the IAM and save, then save copy as IGES and open it the 3D sketch is shows up and is editable. I dont think I need that extra step though.
Is has to do with the IGES option on open.
Windows 7 Pro
6 Gb SDRam
NVIDIA Quadro
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
