folks,
I used autodesk inventor 2014 sp-1 student version, I was trying convert 2d cad to 3d
already open or import the 2d file to the inventor & copy but cannot to be paste in inventor no more button or no function in keyboard control v.
Anyboby can help about this matter!
thanks
You don't use copy and paste.
Start a new sketch, you can then import either an image, dwg/dxf or point cloud. (near the end of your sketch toolbar).
If it's simple the common consensus is to just re-draw. that way you don't inherit the CAD modelling errors which can make extrude and the like difficuilt.
I usually import without the auto constraints option first. Then finish sketch, then edit sketch and run sketch doctor. If I still can't produce a closed loop I extrude the lines as surfaces, maybe 10mm, then sticth the surfaces and create a new sketch-project cut edges and get my closed loop.
You can find this tool on the Autodesk Feedback Community.
https://beta.autodesk.com/callout?callid=AB3EF879579E4B31A1555E24C004F438
You can copy and paste do it all the time to cross checks.
I would never use autocad data personally to make my model but I do use to overlay and check then delete.
To copy and paste just have to be in edit mode on the sketch.
Please refer link below how I import the 2d autocad file.
<iframe width="640" height="400" src="https://chronicle.autodesk.com/Embed/589c3686-ec46-48eb-b7d2-6a86cfe66ecd" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
