Inventor Forum
2d to 3d process
7 REPLIES 7
Message 1 of 8
blugene05
546 Views, 7 Replies
2d to 3d process
folks,
I used autodesk inventor 2014 sp-1 student version, I was trying convert 2d cad to 3d
already open or import the 2d file to the inventor & copy  but cannot to be paste in inventor no more button or no function in keyboard control v.
Anyboby can help about this matter!
thanks
7 REPLIES 7
Message 2 of 8
BarryZA
in reply to: blugene05
You don't use copy and paste.
Start a new sketch, you can then import either an image, dwg/dxf or point cloud. (near the end of your sketch toolbar).
If it's simple the common consensus is to just re-draw. that way you don't inherit the CAD modelling errors which can make extrude and the like difficuilt.
I usually import without the auto constraints option first. Then finish sketch, then edit sketch and run sketch doctor. If I still can't produce a closed loop I extrude the lines as surfaces, maybe 10mm, then sticth the surfaces and create a new sketch-project cut edges and get my closed loop.
Message 3 of 8
blair
Look at Autodesk Labs, for the 2D to 3D tool.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 8
scott.sheppard
in reply to: blair
You can find this tool on the Autodesk Feedback Community.
https://beta.autodesk.com/callout?callid=AB3EF879579E4B31A1555E24C004F438
Scott Sheppard
Program Manager
Autodesk Labs
Message 5 of 8
jletcher
in reply to: BarryZA
You can copy and paste do it all the time to cross checks.
 I would never use autocad data personally to make my model but I do use to overlay and check then delete.
 To copy and paste just have to be in edit mode on the sketch.
Message 6 of 8
blugene05
I did add-in utility 2d to 3d tools for inventor 2014, but cannot import the autocad file.
Message 7 of 8
scott.sheppard
Please attach the file so a team member can try it.
Scott Sheppard
Program Manager
Autodesk Labs: It's Alive in the Lab<>
Scott Sheppard
Program Manager
Autodesk Labs
Message 8 of 8
blugene05
Please refer link below how I import the 2d autocad file.
<iframe width="640" height="400" src="https://chronicle.autodesk.com/Embed/589c3686-ec46-48eb-b7d2-6a86cfe66ecd" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
