Inventor Forum
2015 keyboard commands
3 REPLIES 3
hosford
1264 Views, 3 Replies
Whats up with making me use 3 keys to draw a circle?
ctrl+shift+c
Thaddeus Hosford
NUC9i9QNX i9-9980HK, Win 10 Pro 64
Nvidia GTX 1650
Inventor 2021
3 REPLIES 3
-niels-
in reply to: hosford
Hmm, you're right... it's set to Ctrl+Shift+C...
Doesn't make much sense to me, the only other 2 commands set to "C" are "Create simulation" and "Constraint"...
You can change the keyboard shortcut from Tools > Customize > Keyboard. (Category = sketch)
It'll say there is more than one command assigned to that alias, but that can be ignored.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
mcgyvr
in reply to: -niels-
on the keyboard tab of the customize dialog where you change hotkeys uncheck "Use default multi-character Command Aliases"
-niels-
in reply to: mcgyvr
That checkbox wasn't checked. (at least in my case)
I tried checking/unchecking it but that didn't have a noticable effect.
It can be changed easy enough, the only strange thing is why the default was changed.
Niels van der Veer
The Netherlands
