I JUST saved my assembly file and checked everything back into Vault. Closed the assembly and opened it again in Inventor. When I right click on it to check it out.... it says "Some properties may be out of date. Do you want to update properties?...."
Really?? I just saved it.
Dialog says "...Some..." could it be so kind and tell me which property is out of date??? or, better yet, why am I even seeing this dialog?
I know that I can suppress this and it will NEVER ask me this again, but I really don't like suppressing the dialogs.
Using Vault Pro 2015 and Inventor 2015.
Kirk
Solved by karthur1. Go to Solution.
@Anonymous wrote:
Is there a deleted post here? I would love to know the explanation.
Likewise. I'm having some annoyances with this as well.
Rusty
In trying to get an answer on this, I also logged a support case (Case ID:09618032). What AD basically told me to do was to suppress the dialog so that it will never display. It is some sort of conflict between Vault and Inventor when the file is opened, thus this prompt. They assured me that suppressing it would not cause any trouble and that is what I did.
I have not noticed any problems since doing this.
Hope that helps.
Kirk
Thanks Kirk, that does help.
I wish there was an explanation from Autodesk on this dialog box and what is occuring.
Dave
