Hi
Downloaded Edu Inventor 2014 and when i go to install it says missing files...so i retried and same issue....this is the file that downloaded -
Autodesk_Inventor_2014_Eng_64bit_dlm_001_002.sfx
File size - 3.93GB
Where do i download the missing files please
Yeah seems to be broken on Autodesk´s side, had to use this link when I tried to install it, there seems to be no option to download the second file.
Just copy and paste the links and download should start.
RM
If this helps you out please mark as solution
OK...I have both files and the extracting has stalled at 8.09GB of 8.83GB....finished at 8.1GB and now says cannot open
picture of error attached
I downloaded both files and extracted onto my computer.....it says it is installed but i cannot find Inventor 2014 to run...only Content Center 2014 shows up in programs.....i tried to install again and it shows that Inventor 2014 is Installed but has a tick in Content Centre but it is already installed....
It also says ReCap is installed but i cannot find either
what have i missed or messed up?
It did not even create a desktop shortcut for Inventor 2014..created ReCap and Designview shortcuts....the application file is there but errors
While installing, did something indicate that it was specifically installing Inventor, ie did you see files being written to the inventor folder - No
Thanks for your help
When it extracts the file to destination i do not see any files copying but just a progress bar.When extraction complete i place in serial number and product key and then the only option is to install Content Centre and Vault as it says Inventor 2014 Installed with Green tick....no files are shown during extraction
Still no luck...downloaded the EDU 2014 Inventor version again.....says it is installed but i cannot find .. could it maybe inflicting with Inventor 2013 which downloaded and runs perfectly
I suggest that you do a clean uninstall of Inventor 2014 even if you haven't installed it in the first place following the tipps given here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22100879&linkID=9240617
Regards.
Thanks to both merlob amd m.mees for there help.It now works after the clean uninstall
Hi everyone,
I have the same problem, but with the italian version.
I downloaded Autodesk_Inventor_2014_Ita_64bit_dlm_001_002.sfx ,but when i go to install it says missing files.
Are there two working links for the italian version please?
Thanks.
