Inventor General
Distinguished Contributor
Light_Guy
Message 1 of 28 (871 Views)
2014 OFFSET issues
871 Views, 27 Replies
05-11-2013 05:19 AM
Using Inventor in 2014 Factory Design Suite Ultimate, I have run into an issue using offset in the 2D Sketch realm.
I have created geometry, a rectangle, and am beginning to add other items. I no longer require the dimensions for the rectangle so I delete them. However, once i have done that, the next item that I dimension after offsetting, causes the entire sketch to scale in accordance with the dimension I just set. I have to undo my way back to get my geometry right again and add the dims back and then I can proceed again. I have never had this problem before. Another odd thing, is that I can offset just one side of the rectangle, where normally the whole rectangle would offset. Is this new?
Paul Hamor
"Always good ships!"
blair
Message 2 of 28 (856 Views)
Re: 2014 OFFSET issues
05-11-2013 09:07 AM in reply to: Light_Guy
If possible to post the file and screen captures of the issue. Possible change in workflow to add additional sketch constraints prior to deleting the existing geometry may help. As with different releases, changes to the model kernel can affect how the algorithms interpret the geometry.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Valued Mentor
rhasell
Message 3 of 28 (831 Views)
05-12-2013 07:55 PM in reply to: Light_Guy
Hi
I have not installed 2014 yet so I can't reproduce your issue, but are you perhaps and AutoCAD user? I often see AutoCAD users deleteing their construction geometry/dimensions etc.
Inventor does not like uncontrained geometry, it can become unpredictable, as in your case.  Unless you specifically want the goemetry unconstrained, rather leave the dimensions inplace.
After selecting the Offset command, RMB and select "Loop select" option.
Reg
Autodesk Product Design Suite Premium 2014 SP1-Update 2 Build 222
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please accept as a solution if it fixes your problem.
Light_Guy
Message 4 of 28 (812 Views)
05-13-2013 04:05 AM in reply to: Light_Guy
I am an AutoCAD user but have been using Inventor since the 2010 release and this is the first time I have seen this happen. I have 2011 installed on another machine and cannot duplicate this problem nor can my users who still have 2013.
Will try to post files but have not had much luck doing so lately.
Paul Hamor
Message 5 of 28 (807 Views)
05-13-2013 04:15 AM in reply to: Light_Guy
Your 2013 users should be able to reproduce the behavior, it is common to both. In 2013/14, if a sketch has only one dimension, changing the value of the dimension scales the complete sketch.
Light_Guy
Message 6 of 28 (803 Views)
05-13-2013 04:19 AM in reply to: Light_Guy
I'll check with them again to make sure. That is INSANE. Why would Autodesk let that go like that?? I cannot think of reason one why anyone would want that action.
Paul Hamor
Message 7 of 28 (782 Views)
05-13-2013 06:33 AM in reply to: Light_Guy
This was an enhancement added to 2013 release and is great.
It ensures that your sketch remains proportional after adding first dimension (entities don't end up "crossed-over").
Before this enhancement you had to get your original geometry pretty close to actual size or it could lose shape when dimensioned.  In fact, I used to recommend creating one line, arc or circle and dimension it immediately before doing anything else in a sketch to give a sense of scale.  That  is no longer needed because your sketch automatically scales for you.
Post back if you need to see an example why this new behavior is better.
As far as offsetting is concerned make sure right click Loop is active.  This is one of the few commands that does not return to default.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Light_Guy
Message 8 of 28 (777 Views)
05-13-2013 06:43 AM in reply to: JDMather
Please explain. It is a 2D sketch. How could it not be proportional from the get go??? I drew in a 6x6 rectangle. I am going to modify some of the lines of that rectangle later so I erase the dims. I then try to offset a line .0625 from one side, the whole thing shrinks. That makes NO sense to me.
Paul Hamor
Valued Mentor
SeanFarr
Message 9 of 28 (771 Views)
05-13-2013 06:53 AM in reply to: Light_Guy
JDmather is referring to the first dimension of the first sketch, I think you are having issues somewhere else down the line in the sketch environment.
Previously to 2013 , if you drew a "weird" shape in the sketch environment, and then proceeded to dimension, typically the initial shape you drew would end up crossed over itself. But now in Inventor, they scale this first sketch for you to avoid this.
I am not sure where you are having this scaling issues..
Could you attach the file to help clear up??
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014-Update 2 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.49
Message 10 of 28 (769 Views)
05-13-2013 07:01 AM in reply to: Light_Guy
Light_Guy wrote:
..... I then try to offset a line .0625 from one side, the whole thing shrinks. That makes NO sense to me.
Attach a file here that exhibits this behavior.  I'm not sure what you are really saying as this doesn't sound like anything I recall ever seeing.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
