Inventor General
*Expert Elite*
karthur1
Message 1 of 14 (3,821 Views)
Accepted Solution
2013- Why can't Inventor find my Thread.xls
3821 Views, 13 Replies
07-02-2012 08:42 PM
In my project file, under design data folder options, I have it set to c:\designs\Standards\Styles.  This is where I have my thread.xls located.
When I try to place a threaded feature, Inventor gives me a warning that it cant find the Thread.xls file.
It is looking for this file in c:\Designs\Standards\Styles\XLS\en-US\Thread.xls.  WHY is it looking here?  Where is it getting this path from?
*Expert Elite*
blair
Message 2 of 14 (3,818 Views)
Re: 2013- Why can't Inventor find my Thread.xls
07-02-2012 09:08 PM in reply to: karthur1
Try your Application Options: Under the Design DataCapture.JPG
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
*Pro
sbixler
Message 3 of 14 (3,801 Views)
07-03-2012 04:05 AM in reply to: karthur1
Because in 2013 the Clearance and Threads spreadsheets were moved to the XLS\en-US (or other localized name) folder under the Design Data folder.  So wherever you designate your Design Data, you will need to provide this folder structure under it to place your thread and clearance hole data.
Product Support
Message 4 of 14 (3,761 Views)
07-06-2012 03:21 PM in reply to: sbixler
karthur1,
Like sbixler explained , in 2013  the threads.xls and clearance.xls are located in language specific subfolders of the Design Data folder. This was necessary to accomodate runtime language switching in 2013.
The xls file of one language cannot be used on another language, that is why we had to store them in different subfolders.
As pointed out, the remedy in your case is quite simple, create a XLS\en-us subfolder  below ...\standards\styles and copy the threads.xls and clearance.xls in the en-us folder.
So far the explanation on how it is supposed to work.
We apparently did not take migrated ipj sufficiently into account while implementing this new feature and especially ipj that do not use the [Default] design data location.
Bottom line is that  have logged a defect for the wrong behavior that you are seeing.
1466496 Threads.xls cannot be found when migrating an ipj that has its Design Data path hardcoded
Just to reassure everyone, when you change the Design Data location in 2013 from [Default] to a specific location, everything works fine.
Bob
CAD-One
Message 5 of 14 (3,605 Views)
09-25-2012 02:01 PM in reply to: bobvdd
You said.... the remedy in your case is quite simple, create a XLS\en-us subfolder  below ...\standards\styles and copy the threads.xls and clearance.xls in the en-us folder.
I am not clear where is this ...standards\styles
Can one of you guide me. Does this need any project file modification?
C1
Inventor Professional 2013
Vault Collaboration 2013
Product Support
Message 6 of 14 (3,602 Views)
09-25-2012 02:08 PM in reply to: karthur1
I used the original poster's screenshot to come up with the folder location c:\Designs\Standards\Styles\XLS.
The situation on your machine will of course be different. That is why you could not locate that folder.
The default location of the threads.xls in the English version of Inventor 2013 is at
C:\Users\Public\Documents\Autodesk\Inventor 2013\Design Data\XLS\en-US
Bob
CAD-One
Message 7 of 14 (3,587 Views)
09-25-2012 04:04 PM in reply to: bobvdd
Sorry to ask again.Its a little confusing.  In my case I want to discuss the inventor not finding "Thread.xls" in context to the project file.
In my project browser if I select my project file, in the details window below the
Libraries - Show correct libraries
Folder Options - Show correct Dign Data, Templates & Content Center
If I manually browse to that Design Data folder I can find the the Thread.xls there.
Now some one please guide me what should I replace the Project file -> Folder Options - > Design Data to ?
INVENTOR 2013.PROFESSIONAL
VC2013
C1
Product Support
Message 8 of 14 (3,570 Views)
09-25-2012 05:58 PM in reply to: CAD-One
Looks like the default definition in your project path is correct.
It just seems that your Threads.xls is in the wrong location
What I would do if you get error messages when creating threaded holes in the English version of Inventor 2013  is  the following:
1) Go to C:\Users\Public\Documents\Autodesk\Inventor 2013\Design Data\
2) Create a Subfolder XLS  (if it does not exist yet)
3) In folder XLS create a subfolder en-US (if it does not exist yet)
4)Move your threads.xls and clearance.xls files from folder
into folder
Bob
CAD-One
Message 9 of 14 (3,559 Views)
09-25-2012 08:00 PM in reply to: bobvdd
Bob,
I will try to explain my problem & try not to confuse.
I am not sure if the solution you provided is helping me. becuase my design data path is defined in the ProjectFile.
If change some paths and files in the Design Data folder in the local drive, it wont help (Because per the Project file Inventor will look for design data (Network location)  as defined in the ipj file)
Here is a snap shot of my Project File :
Project File
And I already have a Thread.xls in the location you explained. Here is a snap shot.(But I still get the error)
My question : Do you think that I have to change paths my project file ?
Just so you know we are many engineers using this global project and it defines the Style Library definitions. If I edit the contents to direct to local drive I am thinking it might mess the function.
Please suggest.
C1
C1
*Pro
sbixler
Message 10 of 14 (3,539 Views)
09-26-2012 03:57 AM in reply to: CAD-One
The folder in your case needs to be as follows:
M:\Libraries\Design Data\XLS\en-US\
Place the two files there, and you should be good to go.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
