Inventor Forum
2013- Realistic vs. Shaded with Edges
5 REPLIES 5
karthur1
647 Views, 5 Replies
How do I get my part to be transparent in the "Realistic" view like it is with the"Shaded with edges"?  This is what it looks like with the view style set to "Shaded with Edges".  Notice how it is transparent and you can see thru the part.
Now when I switch to "Realistic", I get this.  Anything that is behind this part is not visible.
I want to be able to see thru the part when in the reallistic visual style.
5 REPLIES 5
mpatchus
in reply to: karthur1
What material are you using for the part?
The color style for that material may not have been set up for realistic appearance.
If you are using the DEFAULT material, it uses a generic material for realistic appearance.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
stephengibson76
if its just 1 part it cant be both solid and transparent... split it into 2 parts
Stephen Gibson
View stephen gibson's profile on LinkedIn
also, it may not suit your needs but shaded with ambient shadows suits our needs much better than the realistic style
Stephen Gibson
sam_m
in reply to: mpatchus
I was wondering whether it's to do with the material too...  but whether it's the material's opacity setting coming into play...  Presumably the material isn't set as transparent, but just a texture with a large masked area to make it look it - as soon as it turns to the ray-tracing mode would it take the material's opacity-settings and assume it's a solid block...  might be worth an experiment with the material's opacity?
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
RobJV
Old post, I know.  Just dealing with a bunch of screwy transparency issues myself.  Not sure if you got everything figured out with this but I wonder if my answer from this post on page 2 might help?
http://forums.autodesk.com/t5/inventor-general-discussion/cutout-appearance-doesn-t-work/td-p/362747...
