We are using C3D 2013 and have recently had 3 different episodes where a dwg file was open and being worked in, CAD shut down without warning and the drawing was lost. As in, it's gone. No longer on the network anywhere. These were 3 different drawings in different projects.The drawings were not new, they had been previously created and worked in by more than one user. Any ideas??? We were able to find a backup file and did not lose everything but still thinking there has to be something causing this. The machine is a Dell Precision T5600, 16 GB of RAM, only had it for a few months. Thank you for any suggestions!
-Jennifer
Solved by mcgyvr. Go to Solution.
Assuming C3d is Autocad Civil 3d.. If so try those forums as this is for Autodesk Inventor and we never loose files
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/ct-p/66
http://blog.microsolresources.com/2013/01/29/autocad-files-that-delete-themselves/
