Inventor General
Orbitron
Message 1 of 11 (991 Views)
2013 - DECAL doesn't function
991 Views, 10 Replies
09-17-2012 06:36 AM
We have recently upgraded to Inventor 2013 from 2012.
I have created a part.  I then created a working plane and then a sketch on that.  I imported a design from ACAD Mechanical 2012 to the sketch and finish the sketch.  However, when I try to apply it as a decal, Inventor refuses to allow me to pick the sketch as the "image" of the decal, therefore I cannot create the decal on the part.
Any ideas what I may be doing wrong? - Thanks
MikahB
Message 2 of 11 (981 Views)
Re: 2013 - DECAL doesn't function
09-17-2012 07:26 AM in reply to: Orbitron
Decals work for me in 2013, but I am always using an actual image file (PNG, JPG, etc.) within the sketch as the decal - not the sketch itself.
Mikah Barnett
All Angles Design
Product Design Suite Ultimate 2014
Windows 7 Professional x64
Intel i7-3770k @ 4.5GHz
32GB DDR3-2400 RAM
GeForce GTX 670 4GB
JDMather
Message 3 of 11 (976 Views)
09-17-2012 07:45 AM in reply to: Orbitron
In 10 years of using Inventor I had never attempted to apply sketch geometry as a Decal, only Image placed in sketch.
I just tried in 2012 and couldn't get it to work as you describe.
Can you attach a 2012 file exhibiting this technique?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Orbitron
Message 4 of 11 (970 Views)
09-17-2012 08:15 AM in reply to: MikahB
Thanks.  Using an "image" worked much better.  I guess I was confusing it with embossing using a sketch.  That's what happens when you don't use these features often enough.  Thanks again.
Orbitron
Message 5 of 11 (784 Views)
02-11-2013 12:38 PM in reply to: Orbitron
Well, I'm back!  Now, I'm trying to do the same thing, but Inventor refuses to import any image (.png, .bmp, ect.) into a sketch so I can use it as a decal.  I've done it before (somehow), but now it refuses to do it.  The Wikihelp is useless.   What h... can I be doing wrong?
JDMather
Message 6 of 11 (772 Views)
02-11-2013 01:46 PM in reply to: Orbitron
Attach the ipt and image files here.
Orbitron
Message 7 of 11 (747 Views)
02-12-2013 05:23 AM in reply to: Orbitron
I tried to attach them, but the forum claims the files are too large.
JDMather
Message 8 of 11 (744 Views)
02-12-2013 05:27 AM in reply to: Orbitron
Find the red End of Part marker at the bottom of the feature browser.
Drag the red EOP to the top of the feature history tree hiding all features.
Save the file with the EOP in this rolled up state. (it will be much smaller)
In Windows Explorer right click on the file name and select Send to Compressed (zipped) Folder. (it will be even smaller)
Attach the resulting *.zip file here.
Orbitron
Message 9 of 11 (727 Views)
02-12-2013 10:17 AM in reply to: Orbitron
OK....trying again....
MikahB
Message 10 of 11 (721 Views)
02-12-2013 10:38 AM in reply to: Orbitron
I was able to apply your BMP file as a decal without issues.  What's happening when you use Sketch -> Insert -> Decal?
Mikah Barnett
All Angles Design
32GB DDR3-2400 RAM
GeForce GTX 670 4GB
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
