Just getting started looking into using the bolted connections to generate the fasteners hardware (Bolts, nuts, washers). We have been using iparts and are looking for something a little easier to use. I copied out the bolt that I need from the ANSI standard content to my "New" library. When I go to place the bolt, I still see the large selection of all the bolts from the ANSI standard content.
Is there a way to reduce this list so that I ONLY see the files that are in my "New Library"? The one that I have highlighted here is the one from "My Library".
Kirk
Solved by blair. Go to Solution.
Thanks Blair.... I just removed the standard "Inventor ANSI" library from the list.
While we are on this..... do you use Autodesk Vault server or a shared location for the content files? Right now, I have the content on a shared server location, but I am thinking I would rather have it in the vault.
Hi
I have another suggestion.
What I have done is change the standards organisation for my Library.
This way it alows you to filter the selection to just your custom libraries.
See below.
Ah, Yes. That will keep me from having to change the ipj everytime I get finished editing/adding to the library.
Maybe I need to start going to AU..........
Kirk
