Inventor General
Member
waldroae
Message 1 of 4 (891 Views)
2012 Crashes When opening part or making new part
891 Views, 3 Replies
02-14-2012 10:50 AM
As soon as I open a piece or try to make a new piece, it crashes! I can open the program but can't use it! I installed it and activated it and I can't use the program at all. I have sent many error reports beacuse I have opened it many times and had it crash many times and have always given my email address. Attached is the Error Report Details screen shot.
*Pro
sbixler
Message 2 of 4 (851 Views)
Re: 2012 Crashes When opening part or making new part
02-15-2012 06:33 AM in reply to: waldroae
Did you turn off virus scanning, set the UAC to its lowest setting, and use an administrator account when you installed Inventor?  If so, did you run Inventor the first time with Administrator privileges?
Employee
MartinBernat
Message 3 of 4 (847 Views)
02-15-2012 07:09 AM in reply to: waldroae
do you have any add-ins running? Try to turn them off and see if it helps. There is an add-in re-registration utility which may also be helpful - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13404176&linkID=9242018.
You may also try to re-register the Inventor.exe (it is also a part of the re-registration utility mentioned above).
Try to run c:\Program Files\Autodesk\Inventor 2012\Bin\Inventor.exe /install ... replace the path with your location of inventor.exe of course. You'll need administrative privileges to run this.
Thanks for posting.
Martin Bernat
Mark_Flayler
Message 4 of 4 (839 Views)
02-15-2012 07:56 AM in reply to: MartinBernat
Oddly enough, I have seen this happen with the Advanced Visualizations in Inventor.  A user (me) turned on in the Appliaction Options to always use the Realistic Visual Style and the Ambient Shadows turned on (these settings are on the Display Tab).  What happend was he could launch Inventor, but as soon as he would try and open a file and the software would load the Visual Styles and the Shadows it would crash without ever getting to the model.
To fix it...a reinstall or repair did not help.
I had to delete the User Profile of the user and then recreate it so the settings would be default for the user instead of what changed on the profile that went bad.  Oddly enough just changing the Application Options would not help because when Inventor would open a file that was created successfully with Realistic and Shadows turned on, it would still cause the same result.  I was never able to track down exactly which file was adjusted by this and Autodesk never actually responded to my problem after I described it to them.  Gremlins, pure and simple. :smileyhappy:
If you have to do this, make sure you back up all your personal files before you delete your User Profile and recreate it.  Luckily I was not using the Administrator profile and had a Domain user profile instead so it just pulled it down from my domain when I logged back in and recreated it.
After recreation, I could open files that were created with Realistic and Shadows, but the Application Options for this is something I stay away from now.  I now use the Document Settings and just set it up in my templates to work the way I want to see the models.  The evil ones to avoid in there are Realistic, Watercolor, Monochrome, and Illustration and then any thing with shadows.  Not saying it wont work for some, but my system did not like it, and I have an Elitebook with a nice Quadro card in it.
Mark Flayler Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
