When I pull up material it list 1 density but when I go to iproperties that material has a much different density therefore giving an incorrect. mass reading. 2 1/2 days to install 2013.
How do you get the density of a matreial in material editor to be the same as the material density in Iproperties?
or is this another autodesk bug?
thx
Solved by japike. Go to Solution.
Have you installed SP1.1 and Update 2?
Attach example file here.
Thank you for the reply. Pretty sure 1.1 is done, update 2 I have no idea. and I cannot install anything, that is up to the IT department. How can i tell is or not? This software is not like any other softwares where you gpo to about and it tells you what is what.
They already spent 2 1/2 days trying to get 2013 to work not sure they want to spend anymore time on this software.
@not2013 wrote:This software is not like any other softwares where you go to about and it tells you what is what.
Huh? That is what I just did? It shouldn't take 2 days to install Inventor?
Might get your VAR to help if IT doesn't know how to install software, something isn't right.
Can you create a simple cube or cylinder that exhibits the behavior you are seeing and attach the file here?
I do not see a "about inventor" anywhere. Could you please tell me where it is so I can ascertain whether update 2 was installed or not.
thx
Yes we are well aware that no software should take that long. But autodesk products always cause much trouble when installing or upgrading according to our IT dept. They say becase the software is not written well, which is what I say myself.
Can you create a cylinder and attach the ipt file here?
Try opening hte little Question Mark in the circle, upper RH corner, drop down dialogue box had the "About" at the bottom.
2 1/2 days to install, maybe your company should be looking to update the IT department
The file you attached shows material as Generic (density of water 1g/cm^3).
@not2013 wrote:
... It is working now but cannot get an accurate mass till I can get density to work correctly. Keep getting 2 readings on the density.
David Tichenor
Design Engineering
(708) 547-2913
Can you attach ipt and screen shots that illustrate this behavior?
If your standard support channels are useless (like mine) then I would try here next time you run into installation issues: Installation & Licensing
Did your IT people follow AutoDesk's installation guidelines? (turn off anti-virus, turn off UAC, update everything, etc.)
of course change in units does not change density. (unless the units conversion is incorrect)
I create a null-weight material: I don't think you can put in a 0.0 density but if you put in something like 0.00000000000000001 for a density you should be fine
I think you are confusing the density of a materal and the mass of an item. Most materials are metric and the model template converts to a unit that matches your model template units.
Yes two different units of measurement. I assumed that they would both be in grams.
That is the problem. Now how do I get Material Editor to show the correct units?
No but that's ok. The densities were listed in different units. The lbs density is incorrect though. It should be the same value only in Grams not lbs. Then the mass reading will be correct.
I need to change the units in the Material Editor now.
THX
Lower left or the materials browser there is an icon with a drop down arrow. Click the drop down and there is an option for setting the units.
