I linked an excel (2010) file with an inventor (2011) .ipt and none of the parameters are showing inside inventor. I was leaving the file external but I embed it also as a trouble shooting step and nothing still. I have no spaces in excel sheet. Is there something special i need to be doing inside excel or inventor? Maybe a tutorial? I followed the help file instructions and some online videos. This is my 1st time doing this.
Ok a few things are wrong to much to explain go read this see if it helps you. biggest issue is you cannot have spaces in the perameter names you have to do it like this
dim_1
length_A
length_B
cant have
dim 1
length A
length B
so go here and see if it helps you
http://inventortutorials.blogspot.com/2011/08/using-and-understanding-linked.html
