Inventor General
kerthivasan
Message 1 of 6 (270 Views)
1 D Stress Analysis
270 Views, 5 Replies
09-24-2011 07:52 PM
Hi.
As a part of my course, I am supposed to do 1 D stress analysis.
It was possible in ANSYS.
But how to do that in AD Inventor? (I can do basic 3 D stress analysis, bu I need to know how to do 1D)
So, is it possible in AD Inventor 2011 or only 3 D stress analysis is possible?
Thanks in advance for your reply.
JDMather
Message 2 of 6 (260 Views)
Re: 1 D Stress Analysis
09-25-2011 09:20 AM in reply to: kerthivasan
What is the design geometry - can you post an example file?
Are you familiar with the Design Accelerators - beam/column/plate?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
kerthivasan
Message 3 of 6 (221 Views)
09-27-2011 01:19 AM in reply to: JDMather
Hi.
My problem is, there is a beam hanging vertically, to which an axial force of 100N is applied.
Now I have to find out the elongation using 1D spar element in ANSYS.
I have to do it as 1D only.
So in ANSYS I will first select the spar element, then draw a line whose length will be same
as that of the beam and th cross-sectional area of the beam is entered seperately in a dialog box that corresponds to the 1D spar element.
So, my question is to know whether I can do it in Autodesk Inventor or not?
Please see the picture at http://www.mece.ualberta.ca/tutorials/ansys/BT/Truss/images/Lines.gif
It is simillar to this, i need to model in Autodek Inventor. I am aware that the truss can be modelled in 3 D.
Also view http://www.mece.ualberta.ca/tutorials/ansys/IT/Density/images/Deform.gif
Thank you.
Distinguished Contributor
kstate92
Message 4 of 6 (210 Views)
09-27-2011 05:01 AM in reply to: kerthivasan
You might want to check out the FEA in AutoCAD Mechanical.
KState92
Inventor Professional 2014 64 SP2
Windows 7 Pro 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
kerthivasan
Message 5 of 6 (164 Views)
10-10-2011 07:23 PM in reply to: kstate92
Thank you very much.  This was what I was expecting.
kerthivasan
Message 6 of 6 (163 Views)
10-10-2011 07:24 PM in reply to: JDMather
Thank you very much.  This was what I expected.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
