yep, me too..always been that way,
why not use a constraint? you want to change it later? then which way it
goes is random (just can't win)
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"KJohnson" wrote in message
news:A8CC9AE9BE64BF15AF7C28C8649C9D7F@in.WebX.maYIadrTaRb...
> I have always had problems dimming 0 if the line or point is in place
> already. I had to drag the point or line a way.
> Kathy Johnson
> "Kent Keller" wrote in message
> news:BA5340B2D5E7C2398070F2751C072767@in.WebX.maYIadrTaRb...
> > Maybe this never worked??? but I have a sketch that had a 0" dim between
a
> projected point
> > and a sketch line. The projected point got sick, so I am replacing it
and
> I can't make a
> > 0" dim unless I stretch the sketch line away so that the dim starts out
as
> more than 0.
> > Not a real big deal, other than it is a disruption of workflow.....took
me
> a minute to
> > figure out what was going on.
> > PS I know all about constraints 8^) In this case I want a dim.
> > Kent
> > Member of the Autodesk Discussion Forum Moderator Program
