For years now I have been using a material I call "NO_MASS".
I created it to use as a core block with no mass/weight.
I manipulate it with a spread sheet and parts derived as surfaces from it alter sheet metal components.
I have just installed inv2014 product suite.It does not seem possible to get the material density lower than 0.001.
As you can imagine if the NO_MASS part or core is sufficiently large the calculated weight of the assembly
will be incorrect.In previous releases I had a density of 0.
Is this not possible now?
I have gone from inv2011 to inv 2014
i73770k
gtx680
16gbram
win 7
It appears to be that way in Inventor 2013 as well.
Hi Matthew,
Thank you so much for reporting this problem. I am able to duplicate this issue with Inventor 2013 and 2014.
In 2012 version, Inventor allows to create a material with 0 density. I will forward this issue to developers for more investigation.
Thanks!
