Jeff Howard writes:
> Could be wrong, but believe larger application addressable memory spaces
> are about all you'll see if it is re-compiled as a 64 bit application; e.g.
> wouldn't expect much, if any, performance (speed) increase. (???)
Yes, some more memory is all you will get. IV could really have its
own 4 GB (provided the machine has more than that) and would not have
to share it with other applications.
> [ It's gonna be quite a while before I look at a 64 bit OS and intend to
> take a good look at Linux when the time comes. 8~) ]
64 bit Linux is as good as 32 bit Linux. So there is no reason not to
use it when you consider to use Linux at all.
If there would only be a Inventor for Linux (or another comparable
software)...
Matthias
