what is the use of this tab???
and what is the difference between structured and model data?
Solved by Curtis_Waguespack. Go to Solution.
Hi shuaib_cad,
The button indicated in this image should help you find your way through some of these things.
(see Bill of Material Views)
I hope this helps.
Curtis
Some other good reading on the subject can be find on the support blog
http://beinginventive.typepad.com/being-inventive/2011/05/exporting-all-level-bom-from-inventor.html
Bob
Hi shuaib_cad,
This is the 3rd time I've attempted to reply and add the further clarification you requested. Unfortunately, the moderators have had to remove some of your replies due to a lack of professional conduct, and therefore my replies were lost. Please remember to conduct yourself professionally, as this is a peer to peer help forum and everyone deserves respect, particularly those who are taking the time to offer you assistance.
As per the section in the help article I noted earlier, the Structured view of the BOM is an organized view of the assembly that differs from the Model view in a few key ways. First the Structured view does not display Reference and Phantom component structures, and any child components of a Phantom components will be promoted and will show in the Structured View.
Secondly, as you might have noticed the Model view contains no item numbers, where as the Structured view does number the item, and allows for those item numbers to be managed, by renumbering, sorting, etc.
More differences to know about:
I hope this helps.
Curtis
Edit:
It looks like bobvdd has provided some more good information while I was retyping.
