Pick one surface, right click, select continue and then the second.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Tim Dougherty" wrote in message
news:58DDD82ECA47401321FA52D41D0DE3D7@in.WebX.maYIadrTaRb...
> I've converted my fixture assembly to a weldment. (5 sided box with a
couple
> mounting blocks inside)
> When I try a weld, the cosmetic weld is intuitive enough, but the fillet
> weld doesn't select in the same way. As usual, I'm missing something. 😕
> Shouldn't I be able to pick two plate surfaces that are perpendicular and
> the fillet weld would fill between them? It only allows me to select
> surfaces on one component)
> Or, pick the inside edge (like cosmetic allows me to) and the weld appears
> Thanks for the help
