Inventor Forum
weldment assy material call out
3 REPLIES 3
rclement
795 Views, 3 Replies
people
i created a wedlment assy with 2 parts that the material is specified as steel
i call this weldment assy into a upper assy and the material is specified as wedlment aluminum 6061
i go to material used in document i see the welded aluminum i see also steel but doesnt allow me to
assign to selelction. dont even know why a material is specified in a assy but i guess you have different material configurations for the same assy
anyway how do i change that so it displays in my partlists
3 REPLIES 3
blair
in reply to: rclement
You used the default Weldment template supplied with Inventor, the default is Aluminum. You need to enter the "Weld" module and select the weld-beads and change their Material to Steel. Start a new IAM and Convert it to a Weldment, select the correct Material and then Save this IAM as your Weldment-Steel Template. You may want to re-name the basic Weldment to Weldment-Aluminum.
Delta Tau Chi ΔΤΧ
rclement
in reply to: blair
ty blair have to try it
lesmfunk
Or, use the same template, create a material called N/A or VARIOUS, and assign it to the Welds.
(Just another suggestion. I prefer to have the minimum amount of templates to choose from. Thanks Blair for directing me to the solution.)
