Andrew In’t Veld
Designer
Andrew In’t Veld
Designer
Andrew In’t Veld
Designer
Andrew In’t Veld
Designer
This really needs to be addressed. No reply since 2007?
First I'm strictly speaking about the annotation of welds in an .idw/.dwg...I'm not addressing weldments at all.
I have a piece of formed sheet metal being welded to a flat sheet requiring a staggered/intermittent flare bevel weld. I can't show this weld because Inventor only allows fillet welds to have their symbols staggered in the weld annotation function (from the pulldown directly above the tail note...it's greyed out unless you have fillets selected).
So the functionality is there, but only for one type of weld?
This failing continues to be true in Inventor 2015. Staggered intermittent welds are available only for fillet welds, not any other type of weld. I continue to hope that Autodesk will improve the functionality.
