Again it is in the dialog box. The "Edge" button that flips which direction the thickness
of the flange faces. If you click it to make the thickness go in towards the base Face
then you will maintain the Width
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"ebjco" wrote in message news:f189c4e.-1@WebX.maYIadrTaRb...
> Hello,
> I was not very clear before. If I create a 3 x 3 x 0.1 face. Then I add an angled flange
to either end. This changes to 3" dimension to something else depending upon where I place
the starting point of the flange. I want to add a tapered flange and keep the 3 inch
outside dimension.
