hi group
is it possible to have a tangent constrain on multiple curves?
see enclosed rough sketch, i would like the curved free end or the arm to be in constant contaced with the wavey top line on the other part, the wavey line is constructed as 3 curves but i can only get the tangent constrain to apply to one of the curves.
i would like the tangent constraignt to move between the curves so the part stays in constant contact with the wavey line. this is just a mess about sketch i suppose a real world instance will be a wheel following a shaped cam plate.
regards adrian
Solved by safiredesignengineers. Go to Solution.
If you were working from Sketch Blocks before moving to assembly of parts where you would use the Transitional, if you can replace the curves with a Control Point Spline you can then add Tangent (this does not work with an Interpolation Spline).
