Inventor Forum
sweep won`t work
5 REPLIES 5
Zac-C
606 Views, 5 Replies
sweep won`t work
What do i change or why does the sweep not work on this sketch
5 REPLIES 5
pkainer
in reply to: Zac-C
Good morning,
everthing works fine with Inv2014.
Peter
since Codename Viper...
WHolzwarth
in reply to: Zac-C
Sometimes creating another 3DSketch by Include Geometry does help. See file.
Walter
Walter Holzwarth
johnsonshiue
in reply to: Zac-C
Hi! The issue is that there is a degenerated line segment (point) in the middle where the two bends are. Sweep does not seem to like the condition. If you replace the two bends with a half circle, it should work better.
Thanks!
Software Test Engineer
pkainer
in reply to: johnsonshiue
this was also my first suspicion. But bend on bend  works fine without a straight pipe segment between (with Inventor 2014).
Peter
pkainer
in reply to: pkainer
1.You have to change radius 110 to a smaller value like 100 or so.
2.sweeping with 3D-Sketch
3.after sweeping Change radius back to 110mm
