Inventor General Discussion
Employee
Shiva_Sundaram
Message 11 of 30 (533 Views)
Re: surface visability in an idw
10-23-2012 09:15 PM in reply to: rhasell
Hi Reg,
No problem. Hope that works out. Sorry I forgot to address you in my post.
-Shiva Sundaram
Inventor Development
Distinguished Contributor
slphantom
Message 12 of 30 (519 Views)
10-24-2012 11:06 AM in reply to: Shiva_Sundaram
so now i have an existing assembly idw and i added this part i downloaded from a vendor site and it does not show up on the idw views. how do i fix this?
Scott
win 7 64 bit sp1
cpu intel xeon E5-2687W0@3.106
eight core
two solid state hard drives
32 gig of ram
Autodesk product design
suite premuim 2014 64bit
Nvida quadro 4000
Space Pilot ver. 1.6.2 2010
slphantom (NNTP handle: scottl)
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 5 years
as scottl
Employee
Shiva_Sundaram
Message 13 of 30 (517 Views)
10-24-2012 11:13 AM in reply to: slphantom
Hi Scott,
Does it appear if you create a new view? If so, then you may want to check to see if the drawing view (which doesnt show the part) has Associative DV = ON (view dialog has a checkbox). If its unchecked, you click on that to make the view associative, the part should become visible by default whenever any part is added to the assembly.
OR you can re-apply design view to an existing drawing and right click context menu.
OR you can select the part from the browser and turn visibility ON (if its off)
If new drawing views also do not  show that, then it might be a problem with the part and I would be happy to take a look at if you want to email it to me - sundarsATautodeskDOTcom
-Shiva Sundaram
slphantom
Message 14 of 30 (513 Views)
10-24-2012 11:53 AM in reply to: Shiva_Sundaram
it shows it as on in my idw browser and if i create a new view of the same it shows up. i got it to show up in other views so just that top level assy idw. i can work around it.
thanks
Scott
win 7 64 bit sp1
eight core
32 gig of ram
Nvida quadro 4000
as scottl
Valued Mentor
rhasell
Message 15 of 30 (494 Views)
11-05-2012 03:30 PM in reply to: slphantom
Hi
Back again. How do you set the view rep for Assemblies?
The parts have the surface switched off, the surfaces are not visible in the assemblies, you can't acces the suface in the assembly tree either, but yet they all come through in the IDW?
Reg
Autodesk PDS Ultimate 2015 Update 1 Build 159
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it fixes your problem.
Employee
Shiva_Sundaram
Message 16 of 30 (486 Views)
11-05-2012 03:46 PM in reply to: Shiva_Sundaram
Hi Reg,
Did you try creating a drawing view with the View Representation CHECKED. The view create/edit dialog should contain a checkbox and if you click on it, it will use the view rep from the assembly document. Make sure that when you create or edit the drawing view, you select the view rep (in the list) which corresponds to the one which has surfaces off.
I know it's a little confusing and change in behavior....
Thanks and hope that helps....
-Shiva Sundaram
Active Contributor
cellt2
Message 17 of 30 (476 Views)
11-05-2012 05:01 PM in reply to: Shiva_Sundaram
I don't think this is just "confusing" or a "change in behaviour".  This is a major addition to the work load and I cannot understand what has possessed AD to hobble its users this way.
Valued Mentor
rhasell
Message 18 of 30 (467 Views)
11-05-2012 09:46 PM in reply to: Shiva_Sundaram
Thanks Shiva
I will try the different workflow.
I gave the workflow a quick test, and guess what, it all worked 100%
The Assiciative check box was not ticked, on that particular drawing, I will keep you updated if find anything strange.
Applying "All surfaces" view rep is still quite painfull.
tx
Reg
chrisreynolds
Message 19 of 30 (370 Views)
06-10-2013 03:59 AM in reply to: cellt2
We are having the same problem, we make mould tools & use the Sculpt command a lot, we copy the part to be made into various details & cut the surfaces away, every file in Inventor now has a surface visible in it, we have to turn them off in the part ipt file, this is not carried over into the assembly as it did previously, so they all have to be turned off individually in the iam file, then all the drawing views need the same doing to them regarding surface visibility.
This is making the process a lot longer & a lot more difficult to follow, can it be put back to how it used to be? we only use it as construction as I imagine a lot of other users do.
Employee
Shiva_Sundaram
Message 20 of 30 (351 Views)
06-10-2013 11:58 AM in reply to: chrisreynolds
Hi Chris,
Point taken. I do agree that this is painful. We are looking to see if drawings can ignore surface visbilities and switch back to the old behavior - no ETA yet though :smileysad:. For the moment, like i said in an earlier post, the workaround is to use design views in the part to control surface visibility and turn them off prior to using them.
-Shiva Sundaram
Inventor Development.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
