Inventor Forum
surface thickening issues
5 REPLIES 5
marcusfriesl
2303 Views, 5 Replies
I have a surface model, made of patches in rhino.  This will be part of an assembly.  I need to thicken the surface to 12mm for the material thickness.
I imported the surface model from rhino, and stitched the surface together, before running the Thicken/offset command.  I get an error "The attempted operation had problems splitting faces and connecting intersection edges into loops. Try with different inputs."
I deleted the stitch, and tried to thicken each patch individually.  The attached part model is how I made out.  A few surfaces still generate the same error message.
One attempt to fix this was in the holes in the surface I deleted the face edges of the thickness, and then patched the outer and inner surface seperately, and then stitching that together as a new solid.  This also only works in certain areas.
Is there an easier way to do this or a solution for achieving this surface thickness.  Any help would be greatly appreciated.
Inventor 2014
Tags (2)
5 REPLIES 5
marcusfriesl
in reply to: marcusfriesl
Also,  the order in which I pick the patches affects which surface will cause the error message.
JDMather
Here you go.
marcusfriesl
in reply to: JDMather
How did you accomplish that?  I would just like to know what I was doing wrong.  Thanks.
yannick3
Hi
1- copy your composite surface to multiple surfaces( feature, copy object or Composite1 RMB, copy object)
2- stitch all surfaces  in one (feature, stitch)
3-thicken the stitched surface and check the quilt option
and that's it
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
marcusfriesl
in reply to: yannick3
Thank you both for the quick response.
I used that method on a different surface as well, and ran into a few issues but modifying the maximum tolerance value in the stitch feature seems to alleviate it.
When I get some more time I would like to build this surface fully in inventor.
Thank you.
