Hi there,
I've got a question about pack and go for frame generator assemblies.
file structure of assembly:
Assembly contains:
- part (with extruded sketch, which frame generator is using)
- frame generator assembly with frames
- other parts constraint to frame generator assembly.
This assembly is a railing around a corner made with frame generator and scepters. (see attachment)
I know the future "Pack n go" to re-use assemblies in the same or other project(-file)
Because the length around a corner is different in each assembly, I tried to pack n go the assembly with the following options: "keep folder hierarchy", "include linked files".
If i want to change the length of the new assembly, the old one is changing too. It's like the "Frame reference model" is still linked to the assembly where i started with.
Maybe I'am doing something wrong?
Please help.
With kind regards,
Paul van Deursen
Tedecon Engineering
(NL)
Thank you for your advice.
Ilogic could be an option, but is something that we never used. I will check it out. This works only if it's the same lay-out. If the structure needs more changes than just a change in length, there will be a problem i guess.
Beside that, it's still strange that Frame Generator made components are not fully "pack 'n go"-able. Or am i making a mistake in the procedure?
Does somebody has good experiences with pack n go frame generator assemblies?
Paul
Hi Paul-tedecon,
The iLogic Copy Design tool can be used to copy designs that do not have anything to do with iLogic ( This tool really should be renamed and refined a bit).
But it currently is the best way to copy Frame Generator designs.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-E74FC143-A73D-4BFF-A74F-DDA157B4EF31
A related link:
I hope this helps.
Curtis
