Inventor Forum
strange behavoir pack n go on frame generator assembly
3 REPLIES 3
761 Views, 3 Replies
Hi there,
I've got a question about pack and go for frame generator assemblies.
file structure of assembly:
Assembly contains:
- part (with extruded sketch, which frame generator is using)
- frame generator assembly with frames
- other parts constraint to frame generator assembly.
This assembly is a railing around a corner made with frame generator and scepters. (see attachment)
I know the future "Pack n go" to re-use assemblies in the same or other project(-file)
Because the length around a corner is different in each assembly, I tried to pack n go the assembly with the following options: "keep folder hierarchy", "include linked files".
If i want to change the length of the new assembly, the old one is changing too. It's like the "Frame reference model" is still linked to the assembly where i started with.
Maybe I'am doing something wrong?
Please help.
With kind regards,
Paul van Deursen
Tedecon Engineering
(NL)
3 REPLIES 3
I've never used the Pack'N'Go for reusing my FG assemblies.
I always stuble my way through the 'ilogic design copy' process. (found under the tools tab when you have nothing open)
I say stumble as I usually end up with messier folder structure than i started with but it avoids any strange linkage issues as renaming/relinking is all done as part of the process.
Thank you for your advice.
Ilogic could be an option, but is something that we never used. I will check it out. This works only if it's the same lay-out. If the structure needs more changes than just a change in length, there will be a problem i guess.
Beside that, it's still strange that Frame Generator made components are not fully "pack 'n go"-able. Or am i making a mistake in the procedure?
Does somebody has good experiences with pack n go frame generator assemblies?
Paul
Curtis_Waguespack
Hi Paul-tedecon,
The iLogic Copy Design tool can be used to copy designs that do not have anything to do with iLogic ( This tool really should be renamed and refined a bit).
But it currently is the best way to copy Frame Generator designs.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-E74FC143-A73D-4BFF-A74F-DDA157B4EF31
A related link:
http://forums.autodesk.com/t5/Inventor-IdeaStation/String-Replace-for-iLogic-Design-Copy/idi-p/38213...
I hope this helps.
Curtis
