Hi, I'm pretty new to Inventor so this might seem a little basis.
I am trying to produce a series of holes along the curve of a spiral. I have drawn a spiral but I cannot get points arrayed along it.
Solved by karthur1. Go to Solution.
After you make the hole, next use the rectangular array command to pattern it around the spiral. In the rect array command, pick the >> to expand it. Click the Start button and pick the starting point of the array.
Look at this for [Update 04/18/2023 by moderation: link not available anymore @karthur1 ] a more in depth study.
Kirk
