I am trying to get a disc (Coin) to continuously rotate 360 degrees on its vertical axis. Can anyone offer a solution?
Welcome to the forum.
Are you talking about animating it or just having the ability to select it and spin it.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Why don't you outline what you have tried and what is not working.
@gazd9 wrote:
... Can anyone offer a solution?
Inventor Studio
Animate Constraint
or Turntable animation.
Take a look at the attached simple assembly. You need to constrain the coin so it spins freely on it's axis and then add an angle constraint that you can drive to get the spin you require.
