Inventor Forum
shrinkwrap problem
2 REPLIES 2
316 Views, 2 Replies
shrinkwrap problem
From an assembly I created a shrinkwrap part. In the options window, I modified the range to plug the holes (default range is 10-999999 mm). The problem is that every time I update the shrinkwrap part, the range changes to the default values.
I am using Inventor 2013 and this problem didn't happen in a previuos versions.
Any solution?
Thanks.
2 REPLIES 2
JDMather
Any solution?
Thanks.
I haven't checked to see if the problem can be reproduced in SP1.1, but that is the obvious first question - are you on the latest Service Pack?
yes I am on SP1.1
Thanks.
