Inventor General Discussion
Distinguished Contributor
CADDapult
Message 1 of 7 (364 Views)
showing removal clearance lines?
364 Views, 6 Replies
01-03-2013 01:03 PM
When creating a piping part, like a strainer, I'd like to be able to show something to represent the area that needs to be kept clear to allow for removal of the filter cartridge.  In AutoCAD I'd just draw a phantom circle and a few lines extending from it to show the needed room.  Does anyone have a suggestion of a way to indicate the area in an Inventor part that won't obscure parts of the main object or other objects that may be located behind?  Transparent solids, or maybe sketch entities?  It's primarily needed for design, but if it can show up in the 2D drawing (without totally blocking what's behind it) it would be a plus.
See the attached file for an example of what we've been doing in our AutoCAD models.
Mike
More of a curmudgeon by the hour
blair
Message 2 of 7 (359 Views)
Re: showing removal clearance lines?
01-03-2013 01:21 PM in reply to: CADDapult
You could model a part for the desired clearance and change it to Reference in the BOM.
Reference components have the following characteristics:
They are ignored in the BOM.
They are excluded from the mass calculations.
They are not numbered, and are not directly included in quantity calculations.
Child components of the reference component are ignored in the BOM.
They are shown with a hidden line style in drawing views.
IV2015 up2 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
CADDapult
Message 3 of 7 (326 Views)
01-04-2013 08:33 AM in reply to: CADDapult
If I understand correctly we would make the equipment item one part and the clearance envelope another part, inserted into the assembly seperately?  While it sounds like it would work it means keeping a library of clearance models along side of the equipment models. I'd bet our designers would "forget" to insert the clearances 95% of the time, and insert them in the wrong spot 3% of the time.
The option I'm hoping for is to have everything contained in the part model so the guys can't mess it up or be lazy not show them.   Would sketches in the part model to show handle swings and clearances be viable?  Is there a down side to doing it that way?
Sorry for being such an Inventor noob. After 25 years of using AutoCAD I'm trying to get us rolling with Inventor.  It's like being a group of professional guitar players who've been given pianos and are expected to play at the same skill level in a few weeks.  There's a lot to learn (and un-learn).
Mike
Curtis_Waguespack
Message 4 of 7 (311 Views)
01-04-2013 09:22 AM in reply to: CADDapult
Hi CADDapult,
I think you can sketch a circle and extrude it as a surface (rather than a solid) in your part model, and use this for your needs. Surfaces will not show in the drawing views by default but can be turned on, and you can turn their visibility off in the part model as needed also.
I often use surfaces such as this as "helper" geometry to make constraining part models quicker.
Some related tips:
http://inventortrenches.blogspot.com/2011/01/how-to-get-imported-parts-and-surfaces.html
http://inventortrenches.blogspot.com/2011/02/round-peg-in-square-hole-autodesk.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
JDMather
Message 5 of 7 (283 Views)
01-04-2013 10:14 AM in reply to: CADDapult
CADDapult wrote:
  In AutoCAD I'd just draw a phantom circle and a few lines Mike
You could do the same thing in Inventor - but I think I would use the surface body suggestion.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
blair
Message 6 of 7 (258 Views)
01-04-2013 01:36 PM in reply to: Curtis_Waguespack
Good idea, I am used to using power tools that I have modeled to check for proper clearances for assembly.
Win7-64
CADDapult
Message 7 of 7 (206 Views)
01-07-2013 05:10 AM in reply to: Curtis_Waguespack
Curtis, I think extruding surfaces will be our best bet.
Thanks to all for your suggestions, they are very much appreciated!
Mike
