I have a drawing that has had the origin indicator hidden.
The part has changed, and I need to move the indicator to the new 0,0 location.
How do I show the origin indicator again, or while it's hidden, move it to the
new location?
Thank you very much for your help.
Solved by Curtis_Waguespack. Go to Solution.
Hi sps_cad_guy,
Assuming this is concerning ordinate dimensions you can right-click on one of the ordinate dimensions and deselect Hide Origin Indicator.
I hope this helps.
Curtis
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thank you Curtis.
It is to a set of ordinate dimensions.
Thank you for your help.
It was to a set of ordinate dimensions,
but I will remember this the next time
I do a hole table.
Thanks again.
