The INV-2012 pipe attached uses the Shell command with 2 different thicknesses.The small end extrusion has also shelled out from inside the pipe.How can i perform the 2 different thickness without the small end pipe being shelled out..I want it to remain solid
Ray
Solved by mcgyvr. Go to Solution.
Solved by JDMather. Go to Solution.
Edit the extrusion for that small pipe and make it a new solid instead of being part of that single solid.
Multiple solid bodies are fun 🙂
If you don't want a feature to be shelled - change the location in history (see attached).
or
Heal the part.
@Anonymous wrote:If you don't want a feature to be shelled - change the location in history (see attached).
or
Heal the part.
There you go 2 more ways to do it.
As for an example.. Just try it yourself.. Create a part with 2 solid bodies (use the icon in the bottom middle of the extrusion dialog)
