Inventor Forum
shell
3 REPLIES 3
387 Views, 3 Replies
shell
I`m trying to shell out the Neck on this volute but it does not work with the Shell feature.What can i do to get the Neck (sweep 1 ) to be Shelled out?
The version attached is 2013
IJC
3 REPLIES 3
WHolzwarth
Perhaps this way ..
Walter
Walter Holzwarth
JDMather
The Shell commands works on an entire solid body - not just a feature.
Either - create that geometry first in your history tree and shell before creating the rest of the geometry
or
create that geometry as multi-body solids so that it can be shelled (you can then Combine if desired, but it looks to me like that should be multi-body anyhow).
Hmmmp, looks like Walter modeled the solution while I was typing.
in reply to: JDMather
