I have made this part using solid modelling.I have not used Sheet Metal tools but can this part be made with Sheet Metal Tools.I have started reading but at this stage do not know how to create with Sheet Metal Tools
Best Regards
James
AD Inventor 2013
hello james..
can you attach your parts?
Hi
Sorry unsure whats happen with the file as i did attached.Please allow me some time and i will try and re-attached
Try using a different browser (IE, Chrome...)
Try zipping before attaching...
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
One of many possible solutions.
Of course the tab would be a separate part welded to the box.
Thank you for sheet metal example.
Would you make the tabs separately and then join the tabs and box together in a assembly file?
If yes would then weld the tabs to the box?
James
