Solved by acleggEHUKY. Go to Solution.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"aritter" <Is
href="mailto:aritter@panoston.com">aritter@panoston.com> wrote in
message
href="news:f1237a5.-1@WebX.maYIadrTaRb">news:f1237a5.-1@WebX.maYIadrTaRb...
there a way to show only what you cut through in a secion view? In other
words, background geometry is not visible. I can turn the individual lines
off, but that is very time-consuming.
thanks,
Andy
"aritter" <thanks
message
href="news:f1237a5.2@WebX.maYIadrTaRb">news:f1237a5.2@WebX.maYIadrTaRb...
for the responses.
Actually, I was concerned with a section view of an
individual part. I guess there is no quick way in that scenario.
Good to
know the choices for an assembly, however.
thanks,
Andy
You can turn off the background geometry by right clicking the section through view you have created in the tree - select 'Edit Section Properties' - Change the 'Section Depth' from 'Full' to 'Distance' and then set the distance to be anything less than 5 - this will then hide anything that is in the background of the section view
Hope this helps.
@acleggEHUKY wrote:You can turn off the background geometry by right clicking the section through view you have created in the tree - select 'Edit Section Properties' - Change the 'Section Depth' from 'Full' to 'Distance' and then set the distance to be anything less than 5 - this will then hide anything that is in the background of the section view
Hope this helps.
Almost 20yrs after the question was asked, but in the end we got the correct awnser 🙂
