Inventor Forum
rotating model using mouse button
7 REPLIES 7
Message 1 of 8
gazadder
434 Views, 7 Replies
Using Solid works I was able to rotate a model by holding down the mouse wheel button. In inventor it pans the image. I have to use the other hand to press F4 to rotate the model. Is there a way to change the pan command of the central wheel button to a rotate command?
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: gazadder
> I have to use the other hand ....
http://www.3dconnexion.com
JD Mather
Autodesk Inventor Certified Expert
Message 3 of 8
Personally, I just miss the rotate command being on the RMB menu like it was
in Mechanical Desktop.
wrote in message news:5582805@discussion.autodesk.com...
Message 4 of 8
Matter of preference.... I programmed the F4 key in MDT to llaunch the
Rotate command. Being an old MDT advocate, I think the command structure in
IV is much better. The more you use IV, the more you will like it.
Dennis Jeffrey, AICE, MICE
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP2, AIP 2008
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
"hdd" wrote in message
news:5582957@discussion.autodesk.com...
Message 5 of 8
You can map F4 to one of your mouse buttons. In the MS Intellipoint driver,
there is a Keystroke option.
Loren Jahraus
Autodesk Inventor Product Design
Message 6 of 8
swalton
I map button 4 on my mouse for F4. One thing that I don't like is that the space bar option for the "glass cube" doesn't work unless you click on the rotate icon. Is there a direct shortcut for the glass cube functionality?
Steve Walton
Inventor 2023
Vault Professional 2023
Message 7 of 8
gazadder
The intelli point thing has done the trick thanks. I just have to make sure I press the LMB and the wheel button down at the same time with the same finger.
Message 8 of 8
stephengibson76
to add to the glass cube shortcut, i would like to program my spacepilot to rotate the view left or right by 90 deg, as you do by clicking an edge of the galss cube, but cant see how to invoke this command
Stephen Gibson
View stephen gibson's profile on LinkedIn
